Lokar Shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2007, 11:02 AM
Semi Retired Child
Lokar Shifter
I just got a car that came with 2 Lokar Shift Knobs. The set screws were taken out of the knobs. On Lokars instructions it says "Do not change the settings of these shift knob set screws" Why and how do I get these set except by guesswork?
Kmac
Old 08-25-2007, 12:29 PM
Crosley's Avatar
Wiki Edits: 1659
Kmac
since Lokar offers different shift lever heights and knobs , I would think there are some instructions or a pdf file some where to guide a person to perform the swap & adjustment.
Old 08-25-2007, 01:05 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
I would call lokar,They will help you i'm sure.sorry i don't know.I'm about to buy one for my coupe.
Old 08-26-2007, 09:33 AM
powerrodsmike's Avatar
Wiki Edits: 161
The Lokar knobs that I have messed with have a pushbutton in the center, The set screw in the main body of the knob is used to engage a slot in the pushbutton, so it won't rotate or pop out. The knob itself is locked onto the shifter "stick" with a locknut.
Set the screw so the pushbutton moves freely. IIRC It is a special setscrew, with a turned down end, so don't lose it.
Later, mikey
BE different....ACT normal.
Old 08-26-2007, 05:20 PM
302 Z28's Avatar
Mikey is correct, plus how far you thread the knob onto the shifter shaft determines how well or not so well the detents are engaged. I have had the knob off my Lokar shifter many times with no ill affect,
Vince
Old 08-26-2007, 07:37 PM
Semi Retired Child
lokar remove
Have you had the set screw out of the knob? Thats what is missing from mine.
Kmac
Lokar shifter instructions supermankbk Transmission - Rearend 9 07-06-2006 05:49 PM
Lokar Shifter Bell Crank bartamos Transmission - Rearend 0 06-01-2006 10:41 PM
What automatic shifter is good novadan Transmission - Rearend 3 02-23-2006 10:45 PM
LOKAR shifter knob buzz jprowse00 Hotrodders' Lounge 4 09-05-2003 05:11 PM
5 speed tranny with forward shifter? Warm_Spit Transmission - Rearend 2 08-13-2003 08:09 AM
