-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   LOKAR shifter knob buzz (http://www.hotrodders.com/forum/lokar-shifter-knob-buzz-14229.html)
jprowse00 10-08-2002 05:24 PM
anybody else having a "buzz" /rattle from -in ,the lokar shift knob ??..i replaced the knob with a LOKAR update , but no change ..bought an aftermarket knob , same buzz problem .. re-hung the exhaust , with good insulators etc , and it still buzzes!!. it really is aggravating on the road , and after an hour or two , i could chuck it..restig my hand on the knob helps , but gets tiring .. anybody have a "fix" , for this condition .. i'd sure appreciate some help , thanks fellows...jim prowse...
Madd Syntst 10-09-2002 12:14 PM
I had one in mine in the truck. Turned out to be that part of the floor pan was resting on the shifter bracket off the tranny. Insulated that and it worked out. Call Lokar, so far, they have been very helpfull to me.
jnix 09-04-2003 07:35 PM
I too have a BUZZ, more like a rattle,
It originates from the tolerance fit center button and the knob body.
I hold the button firm and no buzz,
Anyone have any ideas about how tro remedy this??
tm454 09-04-2003 07:48 PM
Go to a soft mount
Rubber bushings, tightened down to hold the shifter in place. They make a rubber insulator bushings for elect stuff so its not grounded. Do you get the idea?
Todd
Rat Rods Rule!
trees 09-05-2003 05:11 PM
I have experienced this same problem and found that it is an adjustment thing. If you are slightly out of adjustment, the center button does not return all the way out with enough spring tension. Try doing a bit of adjusting like the installation instructions say and you can get it to snap back and not buzz.
Trees
