Long block short block fitted block what do - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2010, 07:09 AM
What parts go into the selling of an engine called?:?:
Long block
Short Block
Fitted Block
Replacement block
Thanks!
T.
Old 01-10-2010, 08:02 AM
302 Z28's Avatar
Long block: Usually a short block with heads, sometimes could include an intake manifold.
Short Block: block. crank, pistons, rings, bearings, may or may not include a camshaft.
Fitted block: Bare block with just pistons and rings. No crank, rods or camashaft included.
Vince
Old 01-10-2010, 01:37 PM
Thanks Vince!!
Couppla questions more..
Timing cover
Water Pump
Alternator brackets
Oil Pan
Fuel Pump
Pulleys
All the above mentionned parts are 'original engine' pieces, would they also be included in the "long block" or are they extras?
Reason I am asking is, I have a numbers and dated and correct suffix coded engine that is coming up 4 sale in Mar. or Apr. and have it with all the above minus the numbers correct intake carb. and distributor..
Would prefer not to appear to be a "buffoon" over-pricing the unit number 1, and secondly, don't want to call it a long block if it in fact might at the time of selling be a short block..
Again, thanks for taking the time, 302Z28..
T..
Old 01-10-2010, 03:26 PM
302 Z28's Avatar
The terminology varies a little on each. A long block would in my mind have the most variability and certainly could contain water pump, timing cover and such, but I have seen engines marketed as long blocks that did not have those items. When you decide to sell your engine just list what is included and I think you will be fine. An engine containing all you listed would fall into the "complete engine" category.
Vince
Old 01-10-2010, 06:12 PM
Thanks Vince in North Texas!!
Ted
Long Block Vs. Short Block chevy53 Engine 6 04-11-2013 06:59 AM
Dart SHP Short Block Camaro2 Engine 2 11-13-2009 07:04 AM
short or long ?? ewhenson Hotrodding Basics 6 08-15-2007 04:15 PM
71 C10 long box to short tumbleweed1 General Rodding Tech 9 07-16-2007 03:28 PM
Are those mile long sanding blocks a gimmick? MARTINSR Body - Exterior 43 11-06-2006 07:03 AM
