-   -   Long Block Vs. Short Block (http://www.hotrodders.com/forum/long-block-vs-short-block-119283.html)
chevy53 07-02-2007 07:31 PM
What are the differences between a 350 chevy long block or short block ? Are there any advantages or disadvantages to either for hot rod application?
Deuce 07-02-2007 07:40 PM
A long block is a engine with the heads already installed ... :)
A short block does not come with the heads.
Deuce 07-02-2007 07:48 PM
http://www.sdparts.com/images/produc...298_detail.jpg
Long Block above ...
http://www.sdparts.com/images/produc...737_detail.jpg
Short block above ... ;)
The term long block and short block have nothing to do with the length of the engine. It has to do with the completeness of the engine.
http://www.sdparts.com/images/produc...609_detail.jpg
This a complete engine ... less the carburetor, fuel pump, starter and the ignition wires. It is the ZZ4 HO crate engine from Chevrolet.
tomthecomic 07-04-2007 04:43 PM
what you want to do
They are corect with the long and short block.
short block are good you can pick the cam heads but you need alot of stuff oil pump pan.
short block are grate but you need intake carb
turn kew or almost is the best. You save money and don't need to spend time tuning.
glen242 07-05-2007 10:22 PM
Advantages are:
If you already have good heads and intake, you can reuse them.
I was able to purchase a short block 383, with my choice of cam and pistons installed, for what I considered a reasonable price, from Kent @ the enginestore.com. He did the machining I requested and used the brand of parts I specified. I checked clearances when I received the block - dead nuts on. Bolted my heads, intake, headers, and distributor on, and have been most satisfied!
rickjohn 04-11-2013 05:32 AM
Find your engine or parts here
The general difference among them is that a long block is as close to full engine assembly, ready to run whereas the short-block is normally seen as the assembly that will be rebuilt when an engine is overhauled
You can get more details on Chevy 350 engine parts here at
[URL="************************[/URL]
Mr. P-Body 04-11-2013 07:59 AM
In simple automotive "English", a "short block" has no heads, timing cover or oil pan. A "long block" has heads, and where appropriate, rockers and pushrods. A "complete" engine has an intake manifold, covers and a pan installed. These terms come from the "rebuilder" crowd, with beginings in the '40s, anyway, maybe older.
Jim
