a long list of questions from a complete newbie - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-17-2005, 08:14 PM
Max Keith's Avatar
Landau
Not a problem. I have seen a few old 4 drs that had been Landaued and they looked pretty sharp that way.
Just a matter of taste.
  #17 (permalink)
Old 01-18-2005, 12:29 AM
New Member
pictures?
If you could find some pictures of them that would be awesome to have a look (much better to see it all finished than just how my mind puts it together - often get it wrong
cheers
Dan
  #18 (permalink)
Old 01-18-2005, 07:54 AM
Max Keith's Avatar
vinyl tops on 4 drs
Been a while since Ive seen any as I havent been to any car shows lately, and dont get any magazines at this time, but Ill keep my eye out.
  #19 (permalink)
Old 03-11-2005, 10:25 PM
Last journal entry: Robs34 - Done my dash
suspension 36
In Aus as in NZ your best bet is a HR holden front end. You can then fit HQ-WB stubs and the disc brakes, a Commodore rack and pinion will need to be shortened slightly (37mm from memory) as the HK-T steering box will interfere with the driver side exhaust and make changing plugs murder - I had a 36 Sloper with the steering box setup that I had bought from a friend so I can speak from experience here. Alternatively the Mitsubishi L300 would fit and has the Ford bolt pattern discs, if you desire you can convert them to Holden using Holden stub axles but here you will need to modify the suspension towers to retain your suspension geometry - Not a job for a Goldfish! Absolute easiest rear end is a 9 inch on parallel springs; newer pickups are good donors for these. Regarding the wood in the bodies - in this hemisphere wood was used for a longer period than the US. If it is in near perfect condition I would retain it as it is quite a difficult operation to replace it although taking your time it is not impossible, use furniture tubing as it is 1.2 to 1.6mm thick and you will save considerable weight, when you come to a complex area make a cardboard pattern and use 1mm cold rolled mild steel sheet. My advice - learn to MIG weld - you will never regret it!! With a smallblock the chassis will only need a 3mm X 37mm round tubing X member with gusset plates onto the side of the top hat section chassis rails but a biggie will need more. last bit of advice, join a club and find some more examples of the breed, taking note of how the modifications have been done. Most important dont let your mates get to you when it doesn't happen overnight - keep at it and you and the missus will be cruisin before you know it.
Later
Rob
  #20 (permalink)
Old 03-13-2005, 04:00 PM
Tazz
leave as much stock as you can.....
my 37 Dodge had a buggered up Mustang II grafted to it...I installed a Meyers Mustang II to replace the botched up one. and a GM posi out of an 86Z28. Some guys mold in all the fenders and such...I like the bolted on look...keeping it looking stock but hopped up the drive train...350/350 and a NEW 12volt wiring harness. Custom interior and paint....Cool wheels and good rubber. Stock gas tank if it dosn't leak and refurbished front and new rear brakes.
Tazz
Rat Rods Rule!
