long shaft PS Pump Vs short shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2012, 08:16 PM
Hi all,
Need a little help here. I'm putting in a sbc enging with a short Wp. Now my PS pump pully is for a Long Wp. setup. So my pullies don't line up. Now, do I need a double pully on the PS pump or do they make a "Short shaft" PS pump for a short WP block?
Thanks
Bruce L.
Old 10-15-2012, 08:51 PM
You use the same pump, with short pump brackets. A pulley change may be needed.
Old 10-16-2012, 06:19 AM
PS pump on short WP
Thanks for the reply,
Yes, I did get the short WP bracket for the PS pump, but I'm not seeing any pully that will line up with my crank pully. That's why I was thinking about the double pully and check it's line up measurements.
Any thoughts?
Bruce L.
Old 10-16-2012, 05:00 PM
There are a ton of different pulleys out there. I wouls check with the source for the short bracket you have, and see what the GM part number is for the correct pulley. There are several short pump brackets, so without knowing what the bracket is, there is no way to know which is the correct pulley. The same basic pump has been used from 64 to the present, in GM, Ford, and Mopar applications. The only difference in mounting for the pulley, some are keyed, and held on with a nut, and more commonly, they are just pressed on.
Old 10-16-2012, 06:03 PM
Thanks enjenjo,
I'll dig into the pully side of things. You see it's a blower engine so the crank pully is tight to the Harm Bal.
Bruce L.
T400 long to short shaft 327NUT Transmission - Rearend 6 08-24-2010 08:03 AM
Short shaft on long shaft tranny sooper Transmission - Rearend 2 07-07-2010 04:14 PM
Short and long shaft TH350's.... and extra long too? 383ram Transmission - Rearend 11 02-27-2009 05:08 AM
Changing T350 short shaft to long shaft Jmark Transmission - Rearend 6 01-17-2004 04:22 PM
