long or short chevy water pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2005, 08:34 PM
97Z28's Avatar
NTI Grad.
ok... so whats the difference between a long and short water pump for a SBC?
Old 07-20-2005, 08:41 PM
Bumpstick's Avatar
Hammer and a torch
Short = early style, Long = late model... As for length I`m not sure but the difference is about 1 1/2 inches... Also the short pump fits tight up against the timing cover while the long pump has a gap of about 3/4 inch...
Others may have actual measurements...?
Old 07-20-2005, 08:49 PM
MI2600's Avatar
Member# 3287
I believe the change was made about '68 or '69 when Chevy changed the alternator from the left to the right sides. I really don't think one functions better than the other.
97Z28's Avatar
NTI Grad.
ok cool. thanks. the reason i asked is because i have to order a water pump for an 81 3/4 ton truck with a 350 tomorrow and i have no idea which pump it has. the guy rebuilt the motor and i dont know which pump is in it.
Old 07-20-2005, 11:11 PM
E.T. divided by $ spent= Speed
Should have a long pump.If there enough clearance to fit a finger tip between the timing cover and the back of the pump its the long one.Most newer SBCs w/ the internal regulator alt on the passenger side use the long pump.
Short pumps are used when the alternator is on the drivers side like on older SBCs.They were also used on corvettes till like 1982 or something like that due to the radiator being tilted back.
Old 07-21-2005, 08:30 AM
GoneNova/406's Avatar
you need the long
Old 07-21-2005, 09:25 AM
97Z28's Avatar
NTI Grad.
ok cool. thanks for the help guys... i really appreciate it.
Old 04-24-2013, 02:21 PM
fat fenders 4 ever
Clock-wise or counter clock -wise?
Hi Guys,
Please allow me to jump in on this with a question. First of all, everything I've read here has been good info on the long and the short of it. However, I want to convert my '93 SBC from the snake belt to Vs.
So how do I ask for a long pump that rotates clock-wise and yet fits my engine? Do I look for a particular model / year? *************************** Thanks for your consideration. And 97Z28' thanks for allowing me to grab onto you thread.
Freedom is't free!
Last edited by poncho62; 04-24-2013 at 07:12 PM. Reason: classified ads not allowed
Old 04-24-2013, 02:34 PM
sedanbob's Avatar
To the right on this page, there is a diagram showing the measurements of the short and long water pumps. CHEVY SMALL BLOCK SERPENTINE CONVERSION PULLEY SETS
Old 04-24-2013, 06:14 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I hope after 8 years he has figured it out.
Cole
Old 04-24-2013, 09:23 PM
sedanbob's Avatar
there has been a lot of that lately - reviving old posts. I usually check - missed it this time!
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
chevy 350 blowing water pump gaskits out airwright Engine 11 08-31-2007 07:05 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
short water pump? need4speed2345 Electrical 1 04-15-2004 10:28 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
