Long or short water pump? SBC-Bracket Configuration etc. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2008, 01:53 PM
Elevinpointsixtoone's Avatar
Hey I happened on to 3 high volume aluminum water pumps for a SBC. 2 are shorties and one is a long. I will keep one and sell the others but I don't know which size to keep. Are there greater accessory mounting options/brackets with a long vs. short pump? I'll probably buy some bracket kit in the future and convert away from the v-belt. At this point I'll have a PS pump, alternator and water pump and that's it. I'll have plenty of room in front of the engine if I wish to go long pump. 57 Chevy with an electric fan. The radiator is near the 6 cylinder (forward) position. Room won't be an issue.
So which style should I keep? Need to make some dough for Christmas shopping here pretty quick.
BTW, I have a March high position alternator mount, driver side, that puts the alternator between the drivers valve cover and the top radiator coolant hose....the alternator hits my tunnel ram so thats gotta go too....I think with all the room I'd rather place the alternator down lower anyway or outside of the valve cover.....
Old 12-02-2008, 03:47 PM
techinspector1's Avatar
Wiki Edits: 326
I would think the shorties would be of more interest to rodders looking for room in early cars, but what do I know?
Old 12-02-2008, 04:58 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Shorties will sell better, and the long pumps are much more common. Accessory brackets are available for the long pumps in a bazillion configurations, but short pump brackets aren't that common. I found that out the hard way because marine engines still use the short pump and I had to fabricate brackets to get what I wanted.
I'd run the long. Old-school rodders want the shorts so they can fit V8s in their model As.
Old 12-02-2008, 05:36 PM
poncho62's Avatar
Wiki Edits: 5
I always liked the long pump configuration......The alternator belt is shorter, less chance of it flipping or coming off.
Old 12-02-2008, 09:44 PM
How is it possible to make the alternator belt shorter by having a longer water pump snout?
Old 12-02-2008, 09:50 PM
poncho62's Avatar
Wiki Edits: 5
On the long pump, the alternator sits in front of the pass side head, tucked in close. On the short pump, it sits way out beyond the drivers side head....needing a longer belt.
Old 12-02-2008, 10:50 PM
freedom53's Avatar
Last journal entry: A Few Years Later...
I went with a short pump and have had fewer options for accessory brackets and/or serpentine conversions. Next time I'd go long.
Old 12-02-2008, 11:09 PM
curtis73's Avatar
Wiki Edits: 16
That's what SHE said.
Sorry. Its been a crazy day.
Old 12-03-2008, 08:01 AM
freedom53's Avatar
Actually I think she preferred thick! something more like a soup can.
Short to long water pump for early sbc etaylo17 General Rodding Tech 4 07-19-2008 07:28 AM
SBC - Water Pump Swap - Long to Short Houston54 Engine 7 03-04-2008 08:21 AM
SBC water pump sexypizzaman Engine 1 01-22-2008 04:27 PM
Pulley Change Out Long to Short Water Pump Mule Engine 7 05-25-2007 08:06 AM
SBC 350 WATER PUMP pitsen3 Engine 1 01-13-2003 11:02 AM
