Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Long skirt SBC pistons
Old 01-14-2004, 11:50 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
unless someone on this site can ID them, you likely will be stuck with buying a whole set, Ebay always has lots of deals on pistons. the 345NP pistons you mentioned, keep in mind there compression height is 1.540 instead of 1.560, most of the basic replacement cheapy flat top pistons are made this way and don`t be fooled if you get them off Ebay or any site that tells you the compression height is 1.560 since ebay is ate up with false advertisement. the coated skirt line Hyper pistons made by sealed power have the true compression height so I would either go with those or KB pistons.
