Long-term parking on crushed rock? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2010, 08:23 PM
widerberg's Avatar
'76 Spitfire, '72 XJ6
Hi, All:
I'm picking up a project vehicle in a couple of weeks and don't have any extra garage space. This means she'll be sitting outside. I know parking on grass will kill the frame eventually, from what I've read on here.
I've been quoted a pretty good price on crushed rock delivered (8ft by 16ft by 4 inches deep).
My question is: will parking long-term on crushed rock, maybe with some heavy mil polyethylene underneath, solve my moisture issues? Or will I still be killing my frame?
Eventually, I'll build some sort of stick-based lean to over top of it to keep the rain off. Something kind of like a carport. Phase three would be sheathing the sides and basically ending up with a shed.
Any advice/personal experiences would be hugely appreciated.
Bo
Old 02-26-2010, 07:20 AM
The plastic vapor barrier is a must and will do better if you can mound/slope it to where the water will drain off instead of pooling beneath the gravel.
Trees
Old 02-26-2010, 09:19 AM
wsdave's Avatar
Some guys are super, I'm not
I would suggest liberal use of WD-40 on the underside, and reapply every month or so. Also, if you plan on using the tires, store the car on jack stands to avoid creating deformed spots on the tires.
Old 02-26-2010, 10:07 AM
widerberg's Avatar
Thanks, Trees and Wsdave. I'm definitely going to take your advice on the mounding of the dirt, before adding the plastic and crushed rocks.
Also, I'm going to look into the WD40 thing. My plan is to get the body off ASAP, then powerwash, clean, and wirewheel the frame to bare metal, weld in patches as required (hopefully none will be), then paint on a rust treatment like Eastwood's Rust Converter, then POR15 or Eastwood's Rust Encapsulator sort of like a primer, and finally topcoat it with a few coats of Valspar Tractor & Implement paint in black. Hopefully, that'll make the frame bulletproof in terms of rot. We'll see.
Old 02-26-2010, 07:01 PM
ericnova72's Avatar
More for Less Racer
Friend of mine restores GTO's, keeps his personal cars in pole buildings with pea stone floors, cars are parked on 12" wide plywood runners out onto the stones. These are chalk mark perfection type resto's and the floor seems to keep moisture down real well.
The mound and vapor barrier advice is spot-on.
Old 02-26-2010, 07:20 PM
widerberg's Avatar
Ericnova72, that's a real interesting idea (having the cars on plywood runners). I think I'm going to do that. Heck, it can't hurt, and if the ply soaks up any moisture that might be lurking, then all the better. Thanks for the idea!
And this won't be a concourse GTO, but an old Land Rover. But their frames don't like moisture, and I don't have three grand to buy a new galvanized frame, so this one's gotta last for a while.
Old 02-27-2010, 10:00 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Main thing I see is have the car in a well ventilated situation..Seems likke the old barn finds have not rusted all that bad where they were dry an well ventilated..seems like the plastic covers trap moisture and we get a lot more rust..
Sam
Old 02-27-2010, 11:55 AM
wsdave's Avatar
Speaking of the ventilation that Sam mentioned: If you cover it or tent it, you could run a portable heater or even a fan under the cover to move the moist air around.
Old 02-27-2010, 03:15 PM
sbchevfreak's Avatar
Licenced Automotive Technician
A product called Fluid Film works well, and does not need reapplication. It can even be used as undercoating.
Need Long Term Outside Storage Assistance JimKramer Hotrodders' Lounge 1 07-17-2006 07:22 AM
Protecting panels in long term project mutt79 Body - Exterior 16 03-04-2006 07:05 PM
long term 48 ford p.u. project dale williams Introduce Yourself 2 10-21-2005 10:29 AM
long term primer chevyman992002 Body - Exterior 16 05-04-2005 11:36 PM
Long Term Engine Storage 6T5FIVESPD Engine 10 01-12-2004 04:51 PM
