Longblock for blown sbc. Howz it sound? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2002, 04:27 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Question Longblock for blown sbc. Howz it sound?
Hey Crew.
Since the Hemi's gone, Im starting on my blown sbc motor and heres what Im thinking so far. Remember its a mainly street motor and will see around 6500 rpm's.
1. 350 4 bolt main, bored 030 over.
2. Scat 9000 crank(7500 rpm rating)
3. Eagle 5140 I beam rods.
Lightning heads with 2.05X1.60 valves, 180cc runners, steel valves, locks, guides, 72 cc chambers.
4. Crane cam's 534/553 lift by 289/296 duration. 226/236 at 050. 112 lobe seperation and a 2500 to 6500 rpm rating.
5. TRW blower pistons yielding around 8 to 1 comp.
6. dbl roller chain or pete jackson gear drive.
Sound good so far? Any suggestions? Thanks HG
Old 09-30-2002, 04:42 PM
roys63's Avatar
Thumbs up
Looks good but scrach the gear drive, robs HP and the blower will make enough Noise!And some good SS exhust valves they can really heat up running a blower as will the headers maybe envest in some header wrap.O by the way my daughter lives in Chillicothe, Scott
Old 10-01-2002, 02:12 PM
Post
Thanks scott. Ive thought about the header wrap, but was still undecided. Whats your girls name? Small town, maybe I know her. HG
Old 10-01-2002, 02:25 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I am not sure without looking, but is that scat crank forged? If not, I would suggest at least a 4130 piece. I would also definately recommend a set of 4340 rods. Dirttrackthunder.com sells the scat 4340 rods with 7/16 bolts for under $300 on ebay. You can also call and get that price. Just my .02.
Old 10-01-2002, 03:25 PM
roys63's Avatar
Post
[ October 07, 2002: Message edited by: roys63 ]</p>
Old 10-01-2002, 10:32 PM
New Member
Post
If you are going to go with the Scat 9000 crank, you might have to go with 6" rods. I have a 350 SBC in the machine shop right now that I am putting a Scat 9000 crank in and they told me that they have had some clearance with 5.75" rods. Jim
