look what was found under 4l60e valve body - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2013, 11:49 PM
can anyone tell me what this is? I took the valvebody off of a 1997-96 4l60e and under the plate on the trans side was this thing in one of the worm valleys. it looks like a little rivet. maybe supposed to be pressed into the case somewhere. I don't think it was hurting anything where it was at but im sure it needs to be put back where it goes. thanks
ID:	73132   Click image for larger version
ID:	73133   Click image for larger version
Old 04-13-2013, 11:12 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Does not look like an OEM part to that transmission
Old 04-13-2013, 11:30 AM
Banned
rivit for the converter clutch??
Old 04-13-2013, 12:25 PM
Faith - Respect - Trust
It's a penny, can't make out the year but definitely a penny.
Sorry, couldn't resist.
Ray
Old 04-13-2013, 04:12 PM
gearheadslife, so that probably means that I need a new converter right? I would say that the p1870 code from worn valvebody is what damaged the converter. ive fixed the valvebody.
Old 04-13-2013, 05:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Although the converter has rivets inside of it on the drive hub... that part shown is not from the OEM transmission or converter
Old 04-13-2013, 08:49 PM
ok, well that's good to know. I guess when the shop rebuilt it they must have let it get in the tranny somehow. thanks crosley
Found a Rivet/Plug? 4L60E 123pugsy Transmission - Rearend 6 05-29-2014 01:49 PM
Parts found in pan on 4l60e, what are they? (pics) SAATR Transmission - Rearend 3 08-13-2010 08:15 PM
4l60e full manual reverse valve body 53belair Transmission - Rearend 1 02-24-2010 11:43 AM
New 350 valve body vs 350 Valve body reprogramming kit terminator0723 Transmission - Rearend 4 04-14-2009 08:41 PM
isolator valve, sleeve, regulator valve for 4l60e? mike 96 ws6 Transmission - Rearend 28 01-29-2006 12:16 PM
