Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - look what i grabbed for $250. 5300 vortec
Old 01-12-2013, 03:34 PM
chevy302builder18's Avatar
chevy302builder18 chevy302builder18 is offline
mr mighty mouse
Last journal entry: shes dropped!!
Originally Posted by 455olds View Post
Those are a great engine. Easy to get a lot more power from it also.
i plan on turbo charging it, and camming. Got the same year ECM for it, gonna have it flashed in the future or pick up a programming system. Also got the 4L80E that is 1 inch longer than my TH350 that has a 9 inch tail shaft, and my truck also is equipped with the adjustments ill have to make with the transmission cross over, although id like an ofset version alot better
Originally Posted by vinniekq2 View Post
looks like a good fit
yea it may or may not go like id like it to go, but the dirty dingo mounts i believe are what im looking at. It has the frame mounts from the suburban i got it from, said it only had 119,XXXX miles on it.
Originally Posted by BruceKoukalaka View Post
Hey buddy the engine should fit 90 degrees toward the front though And it appears some parts are needed to connect it to the rest of the truck!!
yes well said. That will be taken care of like i said im not to scared of this. If i should be, let me know.
