look what i grabbed for $250. 5300 vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2013, 02:47 AM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
Well i got my wish in smaller displacement and better fuel economy. i couldnt really contend with what these engines have to offer. i broke down and looked on car-part.com. not only am i pleased to have almost all of the harness, but im also doing that myself one wire at a time. they all been spliced by the junk yard i got it from. tomorrow im buying the computer for 50 bucks at the same junk yard. lets hope they have the connectors with it, other wise imma grab the genuis through the phone and demand to talk to someone higher up
ID:	70259   Click image for larger version
ID:	70260   Click image for larger version
ID:	70261   Click image for larger version
ID:	70262   Click image for larger version
Old 01-03-2013, 05:42 AM
vinniekq2's Avatar
looks like a good fit
Old 01-03-2013, 12:17 PM
455olds's Avatar
Those are a great engine. Easy to get a lot more power from it also.
Old 01-07-2013, 08:57 PM
Last journal entry: Update
Hey buddy the engine should fit 90 degrees toward the front though And it appears some parts are needed to connect it to the rest of the truck!!
Old 01-12-2013, 02:34 PM
mr mighty mouse
i plan on turbo charging it, and camming. Got the same year ECM for it, gonna have it flashed in the future or pick up a programming system. Also got the 4L80E that is 1 inch longer than my TH350 that has a 9 inch tail shaft, and my truck also is equipped with the adjustments ill have to make with the transmission cross over, although id like an ofset version alot better
yea it may or may not go like id like it to go, but the dirty dingo mounts i believe are what im looking at. It has the frame mounts from the suburban i got it from, said it only had 119,XXXX miles on it.
yes well said. That will be taken care of like i said im not to scared of this. If i should be, let me know.
2003 5300 engine in an express van-changing plugs and wires? Dave S. Engine 1 01-22-2012 01:16 PM
500 stroker banging out at 5300 rpm 69'roadrunner Engine 2 11-11-2011 12:14 AM
Swap out 5300 Vortec Engine & Tranny Ell Engine 1 12-18-2010 05:50 PM
Boring a vortec 5300 to an LS1. zildjian4life218 Engine 15 03-27-2010 01:11 PM
