looking for a 1931 front suspension kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2009, 04:15 PM
Anyone know where I can get a complete front suspension for a 1931 Model A?
Old 06-21-2009, 04:35 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Did you check with Speedway??
Old 06-21-2009, 08:06 PM
Try Magnum Axle
I have a Magnum axle kit under my 30 model A that would work on your car. This axle also uses chevy rotors and calipers. Its been there since 1985 and I have never had a problem with it.
Old 06-21-2009, 09:00 PM
I have looked at Speedway and was just wanting something to compare pricing to.. Where is a good place to get Magnum axles at??
Old 06-21-2009, 09:09 PM
Magnum Axles
Just type in Magnum Axles in the google search engine and that will take you to their web site. You might be able to order directly from them, or they will direct you to one of their dealers.
Old 06-21-2009, 10:50 PM
In my 40 plus years of messing with old cars, I have found that MOST of the time ... I out came out better buying everything from one supplier and @ one time.
Total Cost Involved is giving away a complete Model A street rod chassis ...
http://www.totalcostinvolved.com/index.cfm
I would go there and register ... if I wanted Model A parts ...
Plus they sell dropped axles and everything to modify a Model A frame for today's engines and roads.
I use their stuff on my 32 chassis
Deuce ... Moderator
Ideas on how to modify the front suspension madison069 Suspension - Brakes - Steering 7 10-04-2008 07:18 PM
Thinking about building a custom straight axle front suspension toddshotrods Suspension - Brakes - Steering 9 10-24-2007 08:29 AM
Narrowing a '73 GM B-body Front and Rear Suspension hduff Suspension - Brakes - Steering 2 09-09-2007 08:56 AM
1978 Mustang front suspension marlene kit car Suspension - Brakes - Steering 8 03-14-2006 07:14 PM
T-Bucket owners - Front suspension question cucumber1949 Suspension - Brakes - Steering 3 01-02-2006 06:17 PM
