Looking for 25 mpg from my T-bucket - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-26-2010, 11:16 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by cobalt327
What would be trick, is to have a switched valve that would allow non-lockup until you threw the switch. It probably wouldn't have been a hard to do addition, if you were to have had the chance to do it w/the trans apart.
That's actually what I was thinking about . I may be able to find an article on how to do that somewhere . Should only have to drop the valve body to do the necessry mods , you think ? I'm game for anything , not afraid to get into anything as long as I have the literature to guide me . I used to work on 240 ton trucks with a 2.4 million $ price tag .
  #32 (permalink)
Old 08-26-2010, 11:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I know I've not seen anything so far, on modding the TH350C to only hydraulically controlled lockup, but I'm sure if it's doable (as it seems it must be) there will be something out there on it.
If I see anything, I'll let you know and vice versa. Maybe between us we can get to the bottom of it.
  #33 (permalink)
Old 08-26-2010, 12:49 PM
SSedan64's Avatar
The TH350C TCC Lockup works off pressure from the Governor oil circuit. You can delay Lockup by changing the Pressure switch. They are available from 44psi to 54psi in 2psi increments, maybe more but, that's all I've seen.>> http://www.transpartsonline.com/tpfi...sPartsType=350 higher psi switch will delay Lockup. A low pressure switch may have no delay at all.
  #34 (permalink)
Old 08-26-2010, 04:44 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Sounds great Cobalt . You have been a great help and encouragement to me in gettin' my hands dirty again on some good ol' gas powered iron after a 25 yr break . It's a big change from the big iron at surface coal mines .
  #35 (permalink)
Old 08-26-2010, 04:51 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Thanks . I checked the website and added it to my faves for future ref' .
  #36 (permalink)
Old 08-26-2010, 07:26 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Whew , After lots of looking , here's what I think .
Okay from my basic knowledge of hydraulic solenoids they are either NO or NC depending on application . It seems that the lockup solenoid for a T350C would have to be NC as it takes power to get pressure to the lockup clutch in the torque converter . If somehow someone managed to make the solenoid stay open , (I'd have to take it out to see how it's made to see what was done) it would work just like a stuck open solenoid and that would make the trans go straight to lockup without an electrical signal . A kit from B&M to make it work like factory on a non computer car is $186 and change . So what I'm thinking is that if I put in a new lockup solenoid and control it with a toggle switch ................. Okay . So the next thing to do is take out the solenoid and check it . I'll keep you posted what I find when I check it next week . We will be out of town this weekend .
  #37 (permalink)
Old 08-26-2010, 08:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The simplified diagram is from a source that I don't recall, the diagram for the '80 'Vette is identical to my '80 Malibu except for mine having no cruise control. The B&M PDF is of a kit sold by them, possibly the one you mentioned above.
  #38 (permalink)
Old 08-26-2010, 08:55 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Thanks cobalt . The B&M kit is the same one I looked at on their website . I'm curious now to see what I can do with my lockup. I was even thinking of wiring the solenoid to open when I set my cruise control , but I don't want to void the 3 yr warranty on my Rostra cruise control but cutting into the wiring harness .
  #39 (permalink)
Old 08-26-2010, 10:38 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Making the lockup torque, switch controllable again
I found an old post (2007) on here that talked about blocking the spool for the lockup torque . So , I am just crazy enough that I am going to have to see what I can learn by dropping the pan and taking a look in there one of these days .
Summer to Winter MPG awbazar Hotrodding Basics 1 07-17-2010 12:58 PM
More Holley to Q-jet MPG results 454C10 Engine 15 10-09-2007 09:56 AM
T bucket parts Tbucketman Body - Exterior 4 03-12-2007 05:06 PM
For what it's worth, 2-3 lockup 700R4 good for 1 MPG LanceM Transmission - Rearend 2 06-22-2006 04:43 PM
Help with MPG BillyBob1950 Engine 1 11-27-2002 09:40 PM
