Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - looking for a *************
Old 06-23-2005, 07:50 PM
badazz81z28 badazz81z28 is offline
I think it will differ from machine shop to machine shop. All the machine shops around here say its no problem to match used caps to a a different used block. He said he does it all the time. Blocks are not casted with the caps. the same procedure a machine shop would do is the same GM did in the factory. They cut the caps, drill and tap the holes and line bore and hone.
