looking for a 60 inch rear axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2008, 12:22 PM
71corvette's Avatar
I am looking for 60 inch rear axle possibly from a camaro or firebird, or there any other chevy axles in this general width? I will have aprox 400 crank hp on the motor. thanks
Old 02-11-2008, 12:30 PM
life is a temporary assignment
55-64 Chevy Car, 67-69 Camaro, 64-67 Chevelle, 68-74 Nova,
Old 02-11-2008, 12:37 PM
Irelands child's Avatar
Why fool around with a tough to service diff. with minimal after market parts when you can get 9" Ford in so many widths and ratios from 2.?? to 7.?? (Of course this is only my biased opinion )
Dave W
Irelands child
Old 02-11-2008, 12:44 PM
Dave is right,I have used 9''rear ends in almost all my cars,And never had a problem.If my coupe wouldn't have came with the 8.8,It would have a 9'' in it.
Old 02-11-2008, 12:49 PM
Here is a good site. http://www.quickperformance.com/Tech...us_measure.htm
Old 02-11-2008, 08:23 PM
71corvette's Avatar
I found a Ford 9 inch from a 71 truck it is 61.25 inches. that should work. the pinion is offset on the 9 inch how do you compensate with the driveline?
Old 02-11-2008, 09:50 PM
All of mine had to be cut down,So I just centered all of mine.
Old 02-12-2008, 11:08 PM
An 8.5" unit from a '72-'79 Nova or clone measures right at 60" between the wheel flanges.
97 Ford f350 rear axle nut problems. Rubberman2003 Transmission - Rearend 5 03-21-2009 07:21 PM
rear axle hop bob schildt Suspension - Brakes - Steering 1 11-13-2007 02:34 PM
dana 60 or 8 3./4 rear axle legionlleh Transmission - Rearend 7 03-11-2007 08:44 PM
rear suspension/Welding on Rear Axle redsin Hotrodding Basics 4 05-30-2006 08:25 PM
8.25 rear or 9 inch rear dragrace87 Transmission - Rearend 7 03-20-2003 12:45 PM
