Looking for advice on center console build (with pics) - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2009, 04:22 AM
Last journal entry: more work
Want to wrap this console. Im open for suggestions of materials. Im confident I can do it but since this is the only piece I need to wrap, would it be cost effective to take it to have it done? Going to build a padded lid which will need wrapped too. Could use help on type of hinges to use. Was thinking of making a leather pouch type pocket instead of making something rigid out of fiberglass. Any ideas to make this better/easier are welcome. I reinforced all corners and both sides with fiberglass before the filler.
Here is the console in question. Along with the Dash I fabricated. Going to run the stainless down the center of console and use the same spikes as in the dash. Also showing how the shifter will be. The shifter shot was before the hump was finished.
Old 12-23-2009, 08:30 AM
DanTwoLakes's Avatar
Wiki Edits: 22
That looks very nice. If it was mine, I would cover the whole thing with 1/4" closed cell foam (brand name Volara) and then cover that with the fabric of your choice. The fabric (and foam) would need to be tailored and cut and sewn to fit. It could have french seams or top stitched seams which would really look great. If I get a chance today, I'll fabricate something and post a picture.
Old 12-23-2009, 08:46 AM
Last journal entry: 50 Ply wagon
Go to your local fabric shop and get vinyl material that will go on with a good spray on adhesive. I would be careful where you do put padding as well, cause if you pad something that has a close fit when you put it back , it may be too thick.
Old 12-23-2009, 09:46 AM
Depending on the look you're trying to achieve, tweed may be an acceptable option.
Doug
Old 12-23-2009, 11:05 AM
302 Z28's Avatar
FWIW, most people consider tweed to be a bit old fashioned and dated. That is a nice looking console and will look very good covered in upholstery material. Another alternative is to use it as a buck to make a fiberglass replica of it. Then the fiberglass replica could be smoothed out as required and painted to match either the interior of the car or for color contrast the exterior color.
Vince
Old 12-24-2009, 06:24 AM
Tweed is out. And the all fiberglass painted wouldnt match the theme of the car.
I was thinking stretching some faux leather over the whole thing. The sewn look sounds ok too. Gotta see what shops we got around here. I live in BFE mississippi so its hard to find quality shops of any kind. Im not in a hurry so sometime after christmas ill go talk to some shops. I think we got a couple around here.
I was thinking of coating it like my dash. Thats rubberizd undercoating with a top coat of Black Effex by duplicolor. It actually worked real well. But im afraid ill be rubbing my leg against it enough that I may wear through eventually. Thinking the material streatched would hold up better.
Old 12-25-2009, 11:41 AM
Wiki Edits: 22
O.K., I had some time to show you what I was talking about. We are going to upholster a "console". Please remember that this is just to show you the steps, not the quality of my work. A real live console would be much easier and come out looking much better. Here is the console. O.K., I know it's just a cardboard box, but it will do. The first thing to do is cover the console with 1/4" closed cell foam. I can glue this on with foam to foam glue because the fabric (in this case some white 100% polyester fabric like Ultraleather) will be stapled down underneath the bottom of the console. I start with a long piece over the ends and long part of the top. Then I cut a piece for each side and glue it on making the joints as smooth as possible. They don't have to be perfect because the fabric joints will cover up minor imperfections. Then I cut the fabric making sure I make it long enough to have some extra fabric to pull with, and sew each side on as in the picture. Then I top stitch the seams. ( I used black thread just so it would be easier to see) In this case, one side is a french seam stitched on both sides of the original seam, and the other side is just top stitched through both layers of fabric. (This side doesn't look as good as the other side because I did not pad this side with foam.) Then I just staple the fabric down under the bottom of the "console". That's all there is to it, and even though it's just a cardboard box, it didn't turn out too bad, at least on one side. Your console is a little more elaborate, but the basic steps are the same.
ID:	42788   Click image for larger version
ID:	42789   Click image for larger version
ID:	42790   Click image for larger version
ID:	42791   Click image for larger version
Old 12-25-2009, 12:06 PM
Thank you for showing me that. I like the double french stitch look. Gives me an idea of what to ask for when I go talk to the guys.
Old 12-29-2009, 05:27 PM
Here is the finished result.
Old 12-29-2009, 08:41 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Man that really looks good you got me wanting to build a console for my camaro.
Cole
Old 12-30-2009, 06:20 AM
jon72vega's Avatar
WOW, I could have had a V8!
Nice!
Jon
http://1972vega.wordpress.com/
Old 12-30-2009, 08:44 AM
302 Z28's Avatar
That came out very nice I can see now why you didn't want to paint it.
Vince
Old 02-03-2012, 06:01 AM
rockable's Avatar
That looks great! That is sort of what I have in mind for my Catalina whenever I get back around to working on it.
Old 02-03-2012, 07:15 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
nice, and and it's wide enough that you could hide an 8 or 10"sub and amp under it.. or a pair of 5.25"
center console 67stang Interior 3 01-12-2003 03:08 AM
Center Console Custom79Chevy Interior 4 11-06-2002 02:34 PM
Center Console question / How to make Kevin45 Interior 5 08-07-2002 11:11 PM
custom center console oldcarguy85 Interior 4 05-07-2002 06:52 AM
BUCKET SEATS & CENTER CONSOLE reggiesr Interior 1 11-16-2001 03:19 PM
