Looking for advice - lowering C4 rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2005, 08:06 AM
New Member
Last journal entry: '46 Ford coupe - engine buildup
All - I have a C4 rear in my '46 Ford. Its the rear with the fiberglass mono spring that runs from one side to the other. I need to lower it about 2". I've purchased the "lowering bolts", but that only gave me about 3/4". I'd really like to put air suspension in it, but can't justify the $1k for Shockwaves...
Any ideas?
Old 11-16-2005, 08:45 AM
solidaxel's Avatar
Last journal entry: Project garage complete!
Could you use a longer grade 8 bolt and Nyloc nut?
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
s-10 rear end smallblocked_S-10 Transmission - Rearend 11 06-17-2005 05:43 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
Lowering a 66 stang with a Versailles rear end Sharris Suspension - Brakes - Steering 4 09-15-2002 03:58 AM
