Looking for Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2012, 07:44 AM
Looking for Block
I want to build a budget Big Block Chevy. When looking for a block is there a certain year or type of vehicle to stay away from? Are all blocks the same?
Old 04-20-2012, 09:10 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Ok,
I'll start here and let other Members join in-
There are different Displacements (366,396,402,427,454,502) offered, along with two different Deck Heights (9.8", 10.2"), and with three different "Generations" (Mark IV, Gen V, Gen VI), so lots to choose from-
If you are looking for cheap, 396's are becoming a bit of a boat anchor, as 500"+ Displacements are becoming the norm with all of the aftermarket stroker kits available today.
Staying with the cheap scheme, if you are looking for horsepower, I'd suggest a set of 049 or 781 castings (the 781's replaced the 049's), as they flow well, but they be a little big for a 396, depending on the application.
A 2 bolt Block will do for most, along with a carefully selected stock crank.
It isn't as popular, but I am a Gen VI fan-one piece rear main seal (better sealing), the oil flow path has been moved away from the Oil Pan rail (which is better if you are using a BIG stroker crank), 4 bolt mains as standard-they are a good choice in my Book, but there are detractors-some say they aren't as strong (?)-other than that, the Rods, Pistons, Heads, most of the valvetrain, and other small parts generally will interchange.
Anyway, there are a lot of combinations available (427=454 bore, 396 crank (3.76")-here is a chart of some of the possibles:
http://www.roadsters.com/bbc/#bore
What are you going to do with this, and what is your Budget?
Old 04-20-2012, 11:13 AM
I would like to run a small supercharger,look and sound cool on the street. No competition racing. Are the 90's and up models set up for roller valve train? What is a tall deck block?
Old 04-20-2012, 11:22 AM
35WINDOW's Avatar
You said in your first Post that you wanted a "budget" Big Block-what is your budget?
The Gen VI's are set up for a Factory Roller valvetrain, although you can retrofit Roller Lifters into any Block. A tall Deck Block has a centerline Main Bore to Deck dimension of 10.2"-
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Long block short block fitted block what do opelitis5 Hotrodding Basics 4 01-10-2010 06:12 PM
Need advise for trade. 408 short block for dart iron eagle block sherman8r Engine 6 12-06-2009 04:37 PM
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 07:33 AM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 07:06 AM
