Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - looking for bolt in rack and pinion
Old 03-18-2005, 09:29 AM
theHIGHLANDER's Avatar
theHIGHLANDER theHIGHLANDER is offline
Beimg a "front steer" there's nothing I know of. I had one (72). You can add rack and pinion but thr rack needs to be like 6 to 7inches ahead of the main crossmember to avoid bump steer. You may also look for a rack that has a wider than normal spacing at the inner swivels allowing a longer tie rod end, thus closer to the crossmember and still no bump steer. Seems like late model T/A Z28 might be a good start.
