-   -   looking for bolt in rack and pinion (http://www.hotrodders.com/forum/looking-bolt-rack-pinion-59609.html)
71rsz28 03-13-2005 06:33 PM
Does anyone know of a bolt in rack and pinion application for a 71 camaro similar to the unitsteeroids makes for the 67-69??
theHIGHLANDER 03-18-2005 09:29 AM
Beimg a "front steer" there's nothing I know of. I had one (72). You can add rack and pinion but thr rack needs to be like 6 to 7inches ahead of the main crossmember to avoid bump steer. You may also look for a rack that has a wider than normal spacing at the inner swivels allowing a longer tie rod end, thus closer to the crossmember and still no bump steer. Seems like late model T/A Z28 might be a good start.
OneMoreTime 03-18-2005 09:58 AM
Front steer
Seems to me that one of the fellows here did something like that using the chev cavalier unit..about an 89-90..took a bit of doing but it worked out OK..
Might try a search and see what you come up with..
OMT
poncho62 03-18-2005 12:09 PM
No matter what unit you get, you are going to have to weld in brackets to mount it to.
