looking at a camaro, need advice.
Found a 1991 camaro rs, owner is asking 4000. Has the following stuff done to it.
383 sbc (6k miles on motor) Flat top pistons, 882 heads Lunati cam ( pretty radical ) Wieand tunnel ram w/ dual 525 holleys (power valves blocked) Complete magnaflow exhaust (header back) New clutch, all fluids changed (has reciepts that matched vin) 3.73 with eaton posi (has reciepts at aamco trans.) Downs, Trans whines in and out of gear. Car hums at about 55 and on (thinking maybe allignment) 7 inches of motor sticking through hood (counting hood scoop) Headliner starting to seperate by t tops Some plastic interior pieces damaged Spedo inop. No ac (texas is hot) What would everyone think about this car as far as price and the problems. Just need some advice, will be a weekend/ track car, not daily driven. Has slips proving 12.1 @ 114.xxmph. Thanks everyone, Eric |
I have the cash for it just not sure if I've checked and asked about everything. Trying to see if anyone had advice on anything else to check or ask about. Thanks for the reply though. Still working on the tear down of the studebaker, but wanting something til I can finish that up (many many years from now by the looks of it)
Eric |
"Headliner starting to seperate by t tops"
That would be my concern.....Is the body solid?....Twisted from racing? "T" top bodies are not as strong as solid tops
Ontario Rodders |
If it were my decision I would not buy the car. The hood has been cut and you'll need a new one if you don't want to run a ram setup. The cam and intake aren't supported by the heads at all, so you'll need to tear that all apart and put a decent set of heads on there. You already know you need a trans or to pull that apart.
Its cool that the car has a built motor but IMO it was built incorrectly, so you have a 91 camaro that in stock format in that condition is probably worth about a grand. Sounds like it needs work to the body (probably), interior, motor, trans and other parts. You can find a much better condition 3rd gen camaro for 4 grand or less and build the motor and other items correctly. This sounds like a cobbled together project needing a lot of money and work. My guess is you'll be another 4 grand into it before its right- K |
the headliner is just seperating (adhesive is worn).
The body is in decent shape, at least from what I can tell, all pieces are present and in decent shape, car was recently repainted black. The hood is cut and that is a major thing for me, a buddy from work has a 90 or 91 firebird that he is parting out so the hood is a easy fix, he wants 150 for a 6 inch cowl hood. The carbs/aircleaner is only 4 and 3/4 inches tall. Cylinder heads is a concern but not a massive on at the moment (heading back to iraq within the next 6 months) so a easy fix along with some other stuff when I get back or possibly sooner. The body isn't twisted from what I can tell, the doors open smothly, gaps apear correct throughout the entire car. Transmission isn't really a massive concern either, I could tear it appart one weekend and if it has to sit a bit its ok. Finally divorsed so I have my own house to myself, 2 car garage, mazda 3, durango, studebaker in the tear down process. I have some parrtls laying around I could use on the camaro if need be (studebaker was going to be a sbc, mid way through the build I swapped paths and went to a bbc, have a 383 short block on a stand, afr heads on the shelf. Thank you much for the replies though, Eric |
hey brother check it out im just gonna throw my opinion out their but it sounds like you found a nice car i am a camaro fan myself owning two of them i am not a fan of that particular body style but honestly for the 4 thousand dollars and the fact that it will only be sitting when you go to iraq it dosent seem worth it heres what i did
i deployed 9 months ago and have been looking for a nice 2nd gen camaro for a project car i had someone reliable with truck and trailer on standby but i had a year to find something really nice and not just nice at the moment patience is virtue i think and i ended up with a 78 running driving camaro needs interior work and a wheel bearing to be daily driven for 2g i think i overpaid a lil and then i found my 79 and i paid 4g for it and it has nothing wrong with it other than the last owner didnt finish putting it back together after dumping over 7g into it heres a pic ![]() i would just hate to see you get this car and find a better one in 3 months for the same price my .02c |
| Recent Hotrodders' Lounge posts with photos |
| 68 firebird to camaro rear seat | 68birdman | Interior | 24 | 11-23-2007 11:07 PM |
| need advice on suspension-496 in camaro | 89camarors | Suspension - Brakes - Steering | 1 | 03-09-2007 07:18 PM |
| The Camaro Guy | ZedLepplin | Introduce Yourself | 1 | 03-08-2007 05:55 AM |
| Camaro rear end advice | gavinpierce | Transmission - Rearend | 2 | 08-09-2006 02:17 PM |
| need advice bad! 400 small block | irocan | Engine | 0 | 02-10-2002 04:17 AM |
