Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Looking for an electric cut-off tool that's better than a Dremel.
  #22 (permalink)
Old 02-09-2012, 07:27 AM
Old Fool's Avatar
Old Fool Old Fool is offline
Originally Posted by Stale Trooper
This is probably beyond the scope of the conversation, but I'm getting ready to cut several 4" strips of the 38" wide X 5 rib steel roofing to cure a contractors mistake (he laid the roof panels too high, causing rain to run down the inside wall of my $50K building). I plan on using a 10" abrasive metal blade on either my Table Saw or Radial Arm Saw to do the cutting. I've tried cutting this stuff with smaller (7" Dia X 1/4" thick) blades, and it seemingly took all day just to make one cut! With 60' of material needed to fix the roof, and winter coming on, I want to get it done quickly! the blade I intend to use is 10" X1/8" for $4.79 @ Lowes.
And Yes, I'm going to move the saw outside, wear my welding helmet, a fireman's bunker coat, Welding gloves, combat boots; have a garden hose, and 2 fire extinguishers (type A & Type BC) and an air pack available, with my guardian angel on a 1/2 second response time status, I think I should be able to handle the task.
Aren't you the least bit worried about running the electric tablesaw outside in the proverbial rain storm ? You should at least wear 20K volt linemans rubber gloves inside the wedling gloves, a full wetsuit with booties, and even think about a gfi adapter on the cord. That is the minimium, you could go the extra steps and be safe if you don't want to live on the edge
