Looking for an electric cut-off tool that's better than a Dremel. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-02-2012, 02:03 AM
I have used many different brands of cut off disc in a 4 1/2" grinder working as a Union Pipefitter.
The Walter Zip or Zip + is hands down the best cut off disc I have used.
They are directional,so mount them with the arrow pointing in the direction of ratation and they even last longer than is incorrectly installed, LOL.
$3.25 a disc but worth every penny.
If you do a lot of cutting, get a larger guard for your grinder and use the 6 inch discs, you will get a lot more feet of cut per dollar spent.
  #17 (permalink)
Old 02-07-2012, 10:28 AM
1971BB427's Avatar
I use small 3" wheels in my battery powered DeWalt DC550B cutoff tool. I also use rotary files in it to open up holes. The DeWalt is really a handy tool for quick work and no cord to drag out. The 550B uses either 1/4" or 1/8" collets, so it's versatile and easy to use.
I have a Foredom K.2272 tool with a 4' flexible drive to use with small wheels like a Dremel, but it has more power and the flexible shat allows me to get into really tight places and leave the drive motor out of the working area. I usually keep it hanging above my work bench with the drive cable down to keep it handy, and it gets more bench use than portable use, but when I need something really small it's the best. They're about $330 now, but well worth every penny.
http://www.foredom.net/k2272.aspx
  #18 (permalink)
Old 02-07-2012, 11:27 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
has anyone seen a 4" angle grinder thats cordless..
sometimes the cordless sawsall is just not the ticket at the junkyard crawl..
  #19 (permalink)
Old 02-07-2012, 04:00 PM
1971BB427's Avatar
Yes, DeWalt makes the DC411 cordless 18v angle grinder.
  #20 (permalink)
Old 02-07-2012, 06:10 PM
Last journal entry: How I repaired '51 door hinges
I have a Milwaukee die grinder (electric) and not the one shown in post #6. Mine is smaller and less expensive. About $130.00. With a toggle switch (don't like the paddle switch), about 20,000 RPM. I use 3&4" x .035. I can easily fallow a scribed line.
Silicone caulk has it's place, but not every place.
  #21 (permalink)
Old 02-09-2012, 07:14 AM
This is probably beyond the scope of the conversation, but I'm getting ready to cut several 4" strips of the 38" wide X 5 rib steel roofing to cure a contractors mistake (he laid the roof panels too high, causing rain to run down the inside wall of my $50K building). I plan on using a 10" abrasive metal blade on either my Table Saw or Radial Arm Saw to do the cutting. I've tried cutting this stuff with smaller (7" Dia X 1/4" thick) blades, and it seemingly took all day just to make one cut! With 60' of material needed to fix the roof, and winter coming on, I want to get it done quickly! the blade I intend to use is 10" X1/8" for $4.79 @ Lowes.
And Yes, I'm going to move the saw outside, wear my welding helmet, a fireman's bunker coat, Welding gloves, combat boots; have a garden hose, and 2 fire extinguishers (type A & Type BC) and an air pack available, with my guardian angel on a 1/2 second response time status, I think I should be able to handle the task.
  #22 (permalink)
Old 02-09-2012, 07:27 AM
Aren't you the least bit worried about running the electric tablesaw outside in the proverbial rain storm ? You should at least wear 20K volt linemans rubber gloves inside the wedling gloves, a full wetsuit with booties, and even think about a gfi adapter on the cord. That is the minimium, you could go the extra steps and be safe if you don't want to live on the edge
  #23 (permalink)
Old 02-09-2012, 06:10 PM
Not in the least bit, I was in the Navy and I once saw my Mother-in-Law naked; Nothing can shock me now!!
  #24 (permalink)
Old 02-09-2012, 11:03 PM
evolvo's Avatar
Heathen
These are expensive, but you get what you pay for:
http://www.heavydutystore.com/walter...-pr-63806.html
  #25 (permalink)
Old 02-10-2012, 12:19 AM
nine4gmc's Avatar
this thread is funny, but like everyone else said, safety first! I wear a hat and safety glasses even with a face shield.
I use a 3" cutoff air tool for smaller things, I mainly use 4.5" harbor freight grinders with good wheels. the hf wheels shatter and explode regularly where the good ones actually wear out over time. I also have a 7" hf grinder that I use to knock down frame welds, thick material shaping, edge bevels, etc. to save wear on the 4.5" thats usually set up with a cutting disc anyway. the only good thing about the hf grinders, the hf store is only 2 miles from my shop.
Cutting a circle with dremel tool. Eric63M Garage - Tools 8 07-04-2010 11:17 PM
dremel tool defilade Body - Exterior 1 06-06-2009 01:23 PM
new tool from Dremel: the "Stylus" Jon Hotrodders' Lounge 1 03-17-2006 12:43 PM
Dremel Tool problem ChevelleSS_LS6 Garage - Tools 4 11-07-2004 12:57 PM
Dremel tool for polishing trim? gsrokmix Body - Exterior 8 02-05-2004 02:28 PM
