looking for epoxy or glue.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2011, 01:11 PM
what can i use to bond plastic and wood together end to end that will hold up ive got 2 plastic panels and theres a roughly 6" gap where i can see painted metal, i want it to be a solid 1 piece panel to cover the metal that i can wrap....the part wont have much stress besides the pressure of pushing the mounting clips into the holes in the metal....
Old 01-12-2011, 01:55 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You need to describe where this is going and what it's on, 'cuz I can't picture what you want to do......
How thick is the wood, how thick is the plastic, what kind of wood, what kind of plastic, where is this finished assembly going?
Old 01-12-2011, 02:05 PM
its going on the b pillars on my nissan truck...the newer trucks didnt come with cover panels for this area so i bought the lower panels and im gonna fab the top half...basically th eolder trucks' top half was a plastic piece that the headliner rolled down to and the newer trucks only have the top piece by the top seatbelt bolt and the painted metal is exposed the rest of the way down...since i did a color change i dont want to see the old color in the interior...the plastic seems to be an abs/vinyl mixture nd i plan on using 1/4 mdf....i dotn have a pic of the area sorry...so im using th ethe part that goes to the older trucks and the part for the newer trucks but i need to make a filler to connect the two together..i hope this helps...
Old 01-12-2011, 05:01 PM
Wiki Edits: 22
So there's a 6" gap you want to fill between the seat belt connection near the top of the pillar and the bottom of the pillar, is that right? So it's not really structural, and it doesn't need to be removable right? It also needs to be shaped correctly.
Why not use fiberglass resin over fleece? Then you can shape it correctly and paint it the right color when it's hard, or cover it with vinyl.
Old 01-13-2011, 10:34 AM
thanx for th ehelp...i ended up sanding the 2 plastic parts with 36 grit and i cut slits in them where they would meet the wood so the epoxy would have sumthing to grab...i wasnt about to spend the money for a duramix gun and the tubes so i used a bumper repair kit from the parts house...it held together pretty good and its sandableanyhow ill post sum pics when i get them ready to cover....thanx again....fiberglass was a little to messy for me to deal with in this small area...
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 09:53 PM
Glue Gun? Coodeville Interior 3 06-07-2010 04:43 PM
Epoxy resin instead of epoxy primer sparkydog Body - Exterior 5 03-14-2010 08:46 AM
Epoxy-Filler-epoxy-2k primer-right? jdss Body - Exterior 2 07-08-2008 08:31 AM
Which glue should I use?? sexypizzaman Interior 6 03-04-2008 12:05 PM
