Looking for a fiberglass tilt frontend for my 65 Impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2006, 12:47 AM
I have been doing alot of research on my 1965 Impala 4 door and I have found very little. The reason I bought the car is coz you dont see these where I am from. Well I wanna tilt the front end and I need help. Preferrably, I would like it to be fiberglass to lighten the load of this massive 4 door.I am also looking to put and air bag suspension on it. Any info that will benefit me and my restoration of this classic please help me.
Old 01-14-2006, 07:51 AM
ckucia's Avatar
If you're into making one yourself, you could check out what the kit car guys are doing.
Somewhere on the web there are instructions for pulling a mold off an existing car. A lot of guys would rent a Ferrari or Lambo from some of the high-end rental guys, then cover it with a mold release and pull a mold off it before turning it in.
Apparently, you can do this without damaging the vehicle.
You could build a mold (probably multiple pieces) of the front end. Probably would need to spend plenty of time getting it aligned just right. Then use the mold to build yourself a fiberglass front end.
Bunch of work, but it might be your only option if no one makes one already.
And, you could always build a couple more and resell them after you've made yours.
looking for a bench seat for a 65 impala thegeckoj Interior 7 11-09-2009 08:42 AM
Fiberglass tilt front end Marcus Body - Exterior 7 01-12-2008 02:48 PM
51 Chevy Truck Tilt Frontend 51Panel Body - Exterior 14 07-28-2007 09:34 AM
65 impala electrical problem EazyDuzIt102 Electrical 14 08-04-2005 11:18 AM
tilt fiberglass front end notstock78 Body - Exterior 4 10-04-2003 02:34 PM
