Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - looking to find aftermarket or repro center caps for iroc rims
Old 01-28-2006, 03:38 PM
mrcleanr6's Avatar
mrcleanr6 mrcleanr6 is offline
i used to have an 87 and lost one of these. i just replaced it from the dealer. now its been a long time but from what i remember on the back side there is tabs along the outer edge that snap into the rim. problem i found was the plastic gets old and brittle and when you remove them the tabs crack and break off then wont hold tight into the rim and it just flies off. if you were to find an old one i think you would be lucky if it actually stayed on the rim. your probably going to be better off biting the bullet and spend the $50 on the emblem. even if you found a used one for 25 you really arent saving anything if you end up buying it twice!!
