looking to find out some info on a t10 borgwarner - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 11:48 AM
hi im new to this sight and im looking to find out some info on a t10 borgwarner i just bought the casting numbers on the trany are 13.04.065.903 and 13.04.066,903 and 13.04 097.901 and a 10-77 and there is 2 groves on the cluch side of the trany.i would like to no if its a close or wide ratio and if it will be any good with a 454 big block with 4.11 posi thanks
Old 04-27-2011, 11:51 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
A T-10 on a big block maybe a bit "tender" guys do run them but you may be breaking it if you hit it hard and often..
Sorry--just my take as we used to break those with a stock motor..
Sam
Old 04-27-2011, 12:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
"Close ratio". Second design Super T10. Aluminum case, 1977.
Number of ID Grooves- 2
1st- 2.43
2nd- 1.61
3rd- 1.23
4th- 1.00
Iron cases were stronger. There are better choices for a 4-speed, but if you don't side step the clutch or run slicks/drag tires on a prepped surface- like at the drag strip- it will last for a while anyway. First time it hooks up at the torque peak? Bye bye. Unless a U-joint breaks first.
cant seem to find any of this info on the net 85silverado Suspension - Brakes - Steering 3 01-06-2007 07:14 AM
Can't find any info... JJ350 Transmission - Rearend 15 12-27-2006 03:30 PM
Need Help to find Info countrysidehomes Hotrodding Basics 1 04-14-2004 10:27 AM
Some info you might find useful Kevin45 Engine 0 11-14-2003 11:05 AM
Help Find Info on Engine Fotw Engine 6 08-16-2003 06:59 PM
