looking for a good epoxy - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2012, 10:18 PM
Hey everyone, I'm looking for a good epoxy, it needs to be thick clear and strong. Gluing glass and metal, pyrex actually. Quick drying would be a plus.
Old 11-29-2012, 11:58 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
Try Tap Plastics
EasyCast Clear Casting Epoxy : TAP Plastics
Old 11-30-2012, 06:24 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Man it has been an age since I used an of that stuff but when I did West systems made it..Do a google search though and you will come up with several providers of that sort of material..If all you need is a small amount lots of hobby stores and local parts stores have it on the shelf..
Sam
Wiki Edits: 3
Sam
Old 11-30-2012, 02:52 PM
302 Z28's Avatar
Cannot do better than West System.
Vince
Old 11-30-2012, 07:32 PM
Bad Rat's Avatar
Wiki Edits: 2
Is the west system designed for casting? or just fiberglass layup
Old 11-30-2012, 08:16 PM
bentwings's Avatar
bentwings
I've used West Systems epoxies for a long time both on hotrods and large scale model airplanes. I wouldn't say it is exactly clear, at least not the structrual stuff. Casting resin is clear but it is not the greatest adhesive.
West has various hardners for different temperatures. They all work very well. It is tough and reasonably flexible when cured. You add stiffness with FG cloth and or carbon fiber.
As for sticking to non porous materials.....if you rough up the surface it sticks pretty well. Glass I don't think so. I use glass bowls to mix the stuff in and it pops right out when hard. Plastics work ok if roughed up very well except polyethlyene and anything with teflon. Mixing boards are usually Poly and the stuff pops right off. Sanding and roughing the surfqce makes for a mechanical bond but on wood or anthing porous it really sticks hard.
Metals....again a very rough surface makes a great bond. I have done several funnycar bodies and the aluminum body mounts are holding up very well. These things distort something fierce at high speed and often bend and wrinkle the aluminum work. The mounts still hold tight however.
What's a good value PPG epoxy & urethane primer? TNshadetree Body - Exterior 4 05-12-2012 04:17 PM
Filler over epoxy or Epoxy over filler? Here is some good info satexasf150 Body - Exterior 78 10-16-2011 09:35 AM
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 08:53 PM
Epoxy resin instead of epoxy primer sparkydog Body - Exterior 5 03-14-2010 07:46 AM
Good epoxy primer? Since New PPG dplv stinks on bare metal? zachscc Body - Exterior 3 11-15-2003 10:25 PM
