Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Looking for HELP.. Major Vibration
Old 08-24-2011, 06:54 AM
timothale timothale is offline
Wiki Edits: 27
steering wheel shake
can you switch the wheels front to back and do a test drive and see if the vibration changes. can you tell if there is more or less feel in the steering wheel. depending where the tires are installed ,Has the front alignment been checked ?, A bad u joint will cause a vibration even though you can rotate the drive shaft by hand and not feel any wear. but as Dave suggested check out angles and phasing first,
