Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Looking for HELP.. Major Vibration
Old 08-24-2011, 05:00 PM
trees trees is offline
Another thing to check is proper servicing and torquing of the front wheel bearings. The out of balance condition of the tires could easily have damaged the bearings, especially if they were not properly installed. Additionally, with the MII front end, there are brake kits out there that require different bearings, spacers and dust seals. If the instructions were not followed correctly, you could get the symptoms you are describing.
