looking for help on why engine isnt pulling - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2010, 06:19 PM
guys i have an 87 trans am with a 355 rpm range on cam and intake is 4000-7500 it will only pull to 6300 can some one help its driving me crazy
Old 09-26-2010, 06:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
We will need more info to help you out. Give us all the engine specs and rear gears and tire size as well what transmission also.
Cole
Old 09-26-2010, 06:33 PM
its 355 dart iron eagle heads 202 160 577 580 lift 277 duration 750holley hp carb turbo 350 456 gears 28-10.5-15 tires car with out me is 2820
Old 09-26-2010, 06:36 PM
eloc431962's Avatar
Wiki Edits: 37
What converter and distributer are you running also ? and exactly which intake do you have?
Cole
Old 09-26-2010, 06:39 PM
ita 570/590 lift 266/274 duration has 6000 stall msd probillet dart alum.pro 1intake.tried a 4500 and it blew the tires off every time i romped the gas.
Old 09-26-2010, 09:38 PM
Landshark928's Avatar
FrankenPorsche
Solid or hydraulic roller cam and lifters? Just wondering if you're getting valve float above 6300rpms.
Old 09-27-2010, 05:45 AM
solid cam and lifters with roller rockers
Old 09-27-2010, 11:49 AM
ericnova72's Avatar
More for Less Racer
Could be valve float, what are the spring specs of what you are using??
Give us a rundown on the fuel system, everything from tank/cell to carb, including line size, pickup size, and filters.
Old 09-27-2010, 07:29 PM
not exact on springs but they were ordered with cam and lifters by machine shop it is a buddys motor in my car.1/2 line from cell to pump 8" holley black pump 1/2 to reg.about 15' then 1/2 to y block two 3/8 lines to carb 750 holley hp.82 jets in front and 82 rear with power valve block off
Old 09-27-2010, 08:01 PM
When you say it wont pull over 6300rpm is that when you shift or does it flatten out on the big end? Is your carb a vac secondary? If so your car is too light with your gear and convertor you could actually be really lean.
Old 09-27-2010, 08:11 PM
it doesnt nose dive it just runs out its mech sec
Old 09-27-2010, 08:23 PM
Ive had problems with a similar issue, it was weak valve springs. Although not enough fuel psi at that high of rpm could cause it. Youll also think im crazy but ive had a convertor go to crap and it wouldnt let the motor go over 6,000 we thought it was in the motor but it was the converter. So do does pull really good to 6300 then it just wont go past that untill you shift will it actaully hold its self there?
Old 09-27-2010, 08:24 PM
another thing just thought about we also locked the dist out dont know if that matters.
Old 09-27-2010, 08:26 PM
it will keep going in rpms but you can feel that its not pulling anymore.convertor was just sent off and come back
Old 09-27-2010, 08:37 PM
ericnova72's Avatar
More for Less Racer
Locked out timing won't cause this. Sounds more like valvesprings or fuel pressure. If you don't have a fuel gauge you can read while driving, you could rig up a temporary fuel pressure guage and tape it to the windshield to see if pressure falls at the time the engine goes flat. Don't bring a fuel gauge inside the car, too dangerous.
I'd want to know if the springs were correct for the cam - seat pressure, open pressure, installed height?? Single spring, or double?? Diameter??
New engine, or been together for a while?? If together a while, ever been over revved in the past??
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
Advise for pulling engine JG700 Engine 6 05-16-2007 07:14 PM
