Looking for horsepower for my engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2007, 12:45 PM
Can someone put these specs in their computer program to see what the estimated horsepower should be;
350 chevy 4 bolt main block bored .040
Scat stock cast iron crank, normal stroke
6'' rods
Crower solid cam; .504 lift exhaust, .483 lift intake
Ported and polished '78 era heads 1.94I 1.5 E 76cc chambers
I used a shim gasket to get cr at 10:1
Pistons are KB hyperutectic 11:1
Intake manifold is an RPM air gap
The carburator is a holley 750 with vacuum secondaries
I am also using Harland sharp roller rockers
dynomax headers w/ 1 5/8 diameter tubes
I am estimating around 350 - 375 but just wanted to see what the computer said.
As always, thanks for any and all responses,
rob
Old 12-02-2007, 02:00 PM
DoubleVision's Avatar
Even so I`m no help on a dyno figure, I will say you got a heck of a combo going, but the heads throw it off, why run all that equipment for horsepower only to be held back by the heads? If I had a combo I was building like that, I would build it around the heads, meaning I would have started with a aftermarket set of heads. You can get a set of RHS 190cc runner heads that won`t break the bank.
Old 12-03-2007, 08:37 AM
we need the cam duration at 0.050" to make a good guess. LSA would also be nice to have.
but judging from the lift the cam duration should be about 225-230 on the intake and 230 to 235 on the exhaust.
365 to 375hp would be a good guess.
another 40 or 50hp with a set of afr's
Old 12-04-2007, 05:45 AM
DeputyDawg134's Avatar
Mechanical Animal
Last journal entry: Finally complete and running.
More Horsepower
Put some chrome on it, everyone knows that chrome adds horsepower
Old 12-05-2007, 08:47 PM
Yep, I know the heads need to go. I got them cheap and in good shape, so I cleaned them up, removed the casting flash/ridges in the runners, valve bowl area/exhaust port, etc. I extimated a gain in cfm of 15 on the intake side and 30 on the exhaust side give or take a little. The idea was that a 1.94 head will have a little more velocity that a 2.02 head, the motor was not going to see more than 6500rpm, and with only a .08 difference between the two, I opted out of getting the 2.02 heads
I have since changed my mind, the January '08 issue of stock car racing magazine had an article featuring several heads that got my attention;
- Engine Quest EQ 23 heads
- Dart Platinum Iron Eagles
-RHS Pro Action Cylinder Heads
Right out of the box, either one of these heads will help make over 500 hp with some other key componets.
I am leaning toward the EQ 23 heads.
Also, the part number for the cam in my motor is 274SF from Crower.
Advertised camshaft specifications are;
Intake duration: 274 degrees .482 lift
Exhaust duration: 282 degrees .504lift
I installed the cam "dot to dot" as per OEM specs. I did not degree the cam.
If I degreed the cam the duration at .050 lift is as follows;
Intake: 242deg
Exhaust: 248deg
Intake: .321
Exhaust: .336
Hope this helps on getting a decent Hp figure using someone dyno program.
Thanks for all the responses.
Robert
Old 12-06-2007, 08:05 AM
242/248 is bigger than I guessed. The lift is a little low for that duration but lower lift will be better for cam wear and valve control. I would say your engine could be making a little over 400hp if the carb and ignition curve is tuned right.
A dyno program might even predict 435hp+. It all depends on the head flow which is kind of hard to get right unless the heads have been measured on a flow bench. And even with that, a dyno program will most likely over estimate.
I use the dart iron eagles 200cc and like them very much. However, I'm pretty sure I would also like afr's or edelbrock heads. My engine (362, 11;1 cr) is making about 450hp with a 292H compcam (244/244 duration, 0.501 lift) with the dart heads. I base my estimate on 120 mph trap speed in the 1/4 mile and a 2800 pound car.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Engine....whats it worth? chevyusa1 Engine 6 06-11-2007 07:43 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 08:50 AM
