Looking for info on interchange of 1950 f2 truck body to 1986 3/4 dodge extended van - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-22-2004, 06:49 AM
I,m trying to find info on a swap of my 1950 f2 pickup truck body to the frame of my 1986 B-250 3/4 ton dodge extended van.
Old 07-22-2004, 06:52 AM
85citation's Avatar
Life's a small bore.
Last journal entry: The engine's in!!
Good luck with that!
Old 07-22-2004, 07:54 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Why?
Old 07-22-2004, 10:20 AM
poncho62's Avatar
Wiki Edits: 5
Not a chance, Kenny....................the van is a unibody.
Ontario Rodders
Old 07-22-2004, 10:48 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
use a regular later model truck frame
Old 07-23-2004, 05:49 AM
Ok but their is a full frame under the van so why can't it be used? Also what about rebuilding the truck as is I want to pull a 5th wheel camper with it. I have a 351 C 4 bolt main from a 70 mustang and was concidering putting it in and using the trany from the dodge and rearend as well. What does that intail? Thanks for the help. Ken C.
Old 07-23-2004, 07:26 AM
Wiki Edits: 21
It will entail a lot of work and a lot of money.
Old 07-23-2004, 08:28 AM
85citation's Avatar
I might be wrong, but you might be further ahead to purchase a ready made chassis and bolt on your engine and tranny. Even though the van LOOKS like it has a separate chassis, it is most likely unibody. That doesn't mean you can't use parts of the van to build the truck, but either way you slice it, you are looking at years of work and tonnes of cash.
I really don't mean to discourage you, but you need to plan and count the cost before cutting into anything like this. A little research will go a long way to completion of a great project vehicle.
