looking for juice brakes for my 31 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2006, 05:13 PM
R Gassman
Last journal entry: 31 chevy Top on
Hello all, I am still trying to come up with a juice brake option for my 31 chevy front axle, without swapping the whole axle. Has anyone had any luck finding newer model drums/spindles and backing plates that will fit a 31 chevy stock axle?
Thanks again
Ron
Old 12-03-2006, 05:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I moved this to the brake forum...... mayb a bit more help here.
thanks.
Old 06-03-2014, 05:59 PM
Ron a1954 chevy truck axle has juice brakes and a larger king pin the springs on your 31 will work with this axle Mooseman
Old 06-03-2014, 06:24 PM
BOBCRMAN@aol.com's Avatar
I haven't found any that will bolt on. Major difference with spindle width. Newer stuff is shorter bearing to bearing.
If you have the facilities... I have used Ford Rotors and 78 up metric GM calopers with a simple fabbed 3/8" plate for caliper mount. Shorten, drill and re-thread the spindle. Match up bearings/seals to spindle.
Many years ago converted one to VW rotors with Vega calipers. Too much work...
Old 06-04-2014, 08:49 AM
Wiki Edits: 27
6 bolt wheels ?
I have some 20's chevy bodies, chassis and a late 40;s pickup front axle, have been collection info for a someday build. here's a link to using nissan 4 X 4.. 6 bolt rotors. the caliper brackers don't look neat, also check out 70's full size Blazer 4 X 4 combo backing plate caliper mount. or buy some caliper brackets from Speedway.
RIP Speedy Bill Smith
29-59 Chevy straight axle 6 lug disc brake project | The H.A.M.B.
Power brakes on 1960-1966 Chevy C-10 ss crazy Suspension - Brakes - Steering 5 09-18-2014 08:53 AM
power brakes on a 53 chevy CARGUY Suspension - Brakes - Steering 11 11-09-2004 09:08 PM
55 chevy? about using 84 buick disc brakes DeathByGreaser Suspension - Brakes - Steering 2 04-26-2003 07:43 PM
48 Chevy Pickup Brakes Dave E Shank Suspension - Brakes - Steering 2 11-21-2002 11:55 AM
52 chevy After market brakes? Haensley Suspension - Brakes - Steering 2 03-21-2002 05:41 PM
