Looking for material to change my interior wood grain to another style - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2005, 10:37 AM
New Member
I am looking for some material to recover some pieces of my interior, which are already a faux wood grain, to another style.
Presently, I have a dark, oak like look on the door panels, and I desire to go with a lighter, maple look.
Any retailers selling a product like this? It needs to go around some tight surfaces, too.
Old 02-28-2005, 07:34 PM
kristkustoms's Avatar
First name...............Shawn
http://www.beacongraphics.com/avery-print-film.html
Good luck forming it around corners though...
Old 02-28-2005, 08:45 PM
New Member
Thanks, I'll check it out
Old 03-03-2005, 12:19 AM
pzatchok's Avatar
OddJob
Avery makes a great product.
I just used a Mahogony of theirs to do a "woody". A hair drier will work to soften up the material enough to stretch it a bit around bends.
Practice on some similar parts to get the feel for just how much it will stretch. Work slow and have patience. If it takes a bit longer than you think it should then your doing somthing right.
I have tried out 'doller general' shelving film and found it stretches good also. Though the Avery products seem to have a far better glue.
I'll post a few picks this week end.
Old 03-03-2005, 09:34 AM
New Member
Where do I find Avery products?
Old 03-03-2005, 01:04 PM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
At any sign shop that does vinyl signs.
Averygraphics.com
Maybe another is FDCfilms.com, but I don't think they do wood grain.
Avery options:
Cheyenne Teak
Bravo Burl
An EASIER way, is to research faux finishes at Home Depot and do it in paint. Saw it Garlits Museum for an old Ford Dash. Looked pretty realistic.
Old 03-03-2005, 01:18 PM
66Caprice's Avatar
Move It On Over!
What do they mean by punched or unpunched? Which type is the right type to get for dash panels (like in a 66 with mostly flat panels)?
Thanks!
Dan
Old 03-03-2005, 07:36 PM
That wouldnt matter for you...
Punched means the edges of the rolls have a punched edge. These holes allow the film to be fed through a plotting cutter. Remember the old dot-matrix printer paper that fed through printers in one long sheet and you tore it off at the perforations? Its used just like that to feed it into the plotters.
Old 03-04-2005, 10:00 AM
New Member
I wasn't paying attention...an avery link was supplied in the very first post.
Thanks
Old 03-05-2005, 05:10 PM
66Caprice's Avatar
Move It On Over!
Click Here
