Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Looking for a MIG to Tack Panels - Opinions?
Old 06-07-2010, 06:03 PM
reddogracing reddogracing is offline
Originally Posted by oldred
Even the best MIG is going to require very clean metal, not so much a problem on thicker material but an absolute must when working with body panels. Just tiny specks of paint, rust, seam sealer or dirt is going to cause blow-through and all too often the machine gets blamed! If you are having trouble with TIG because of less than clean enough metal then you will still have the same problem with a MIG regardless of the machine's quality.
Thanks, I must have mis-remembered that, maybe it was stick, or maybe it was just wrong and nothing welds dirty stuff better. But 90% of my complaint is needing two hands and a foot under the car.
And I agree that bigger is better, but I don't intend on using MIG for anything more than body panels that are hard to access as I like TIG (of course I have never used MIG). If this was going to be my primary welder, I would have just bought a Miller/Lincoln and been done with it
