Looking for a new Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2012, 11:51 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
Im looking for a new carb for my 350, that I just put together. Im sure you guys know that I was working on a 400 SBC and I had oil pump failure.
Anyways I put the 400 heads on to the 350 that were ported, and polished and, I put the cam in it that I had recently purchase
Duration @ .050" 214 int 214 Exh
SAE duration 287 287
Lobe spread 105 115
lash Hydraulic
Valve Lift ".444 ".444
Cam Lift ".296 ".296
What CFM would I look for to put on here. The qjet I have right now keeps puking gas out of it and I had a carb guy rebuild it..
any help is appreciated
Thanks
Ed
Old 03-20-2012, 06:45 AM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
Nothing bigger than a 650cfm.If you have an auto trans go with vac. secondaries, manual trans mach. secondaries.Adjustable air bleeds are nice to have.
Old 03-20-2012, 07:22 AM
400smb_s10's Avatar
Back Yard Junky :)
thank you very much
Old 03-20-2012, 07:39 AM
Roger Mabry's Avatar
Take your Qjet to Sean Murphy (SMI) = expert
I have QJets on my cars that were rebuilt and tuned by Sean Murphy of Huntington Beach, CA. He owns SMI or Sean Murphy Induction. They are
the best carb for street/strip use and he can make yours right.
I have two 383's (one 700R and one 200R) with QJets and get 14-16 mpg with them and one has 410 HP and 470# torque in a heavy car.
They work great, start easy and work well without messing with them all the time.
Best carb spacer style Edelbrock carb truckboy61 Engine 2 07-24-2011 09:18 AM
holley carb backfires threw carb talleyho Engine 61 05-25-2011 10:03 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 12:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 10:44 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
