I am looking at a Juki LU 563 it comes with table and several feet. It looks like its in real good shape. It has a clutch motor, which I would have to change to a servo(I'm a rookie). How much is it worth? Asking price is $900. How much would it cost to covert to servo? and is this something I can do myself? Just starting on doing my own interiors, I did my last car w/ a regular machine and would like to upgrade to something a lot nicer. Thanks
I would say that's a VERY good price for that particular machine in that condition.
Give the clutch motor a try before you feel you need to run out and buy a servomotor, anyone who has used an industrial machine for more than 5 years learned on a clutch motor. It's just a matter of coordination and slipping the clutch to control the speed of the sewing head. Took me maybe an hour of practice to learn to use a clutch motor. I now have one power stand with a servomotor and three with clutch motors and it makes no difference which one I use.
If you feel you must swap out the clutch motor for a servomotor, cost is under $150 and the servomotor is usually a drop-in replacement, no alterations required. You might need to buy a different size belt if there is not enough adjustment to use the current belt.
I agree with Ed, that price is very good for that machine. As far as the servo motor vs. clutch motor is concerned I am sold on Servo motors if for no other reason than I don't have to listen to the clutch motor running all day any more. I sewed for 30 years with a clutch motor and would have no problem using one again but why worry about controlling the machine when you don't have to? All three of my machines are retrofitted with 1/2 H.P. Reliable 3000 or 4000 servos, including my heavy duty Singer 144W204 long arm.
Also, while a servo will bolt right in where the clutch motor was, Ed is right that you will have to change the belt. All three of my machines were out of the adjustment range to keep the old belt. You will have to also adjust the linkage between the motor and the foot pedal, it would be a miracle if that all lined up correctly.
How do you know what belt to buy once you install a servo motor? Is it a standard reduction in belt O.D. when switching from a clutch to a servo or will a measurement need to be made based off the final pulley locations?
The only way to know is to mount the servo motor. The servo will probably not sit in exactly the same place from the pulley on the sewing machine as the clutch motor did. There is some adjustment, but you're probably going to need a belt 1 to 2" longer or shorter than what you have now.
To figure out belt length, measure from the center of one pulley to the center of the other pulley. Then measure the diameter of the two pulleys, multiply the total diameter times 3.1417 (Pi), divide that figure by two, and then add 2 times the length of the distance between the center of the pulleys.
If the top pulley is 5" in diameter and the bottom pulley is 6" in diameter and the distance between the centers is 12", you need a belt 41.28" long. That's 11 times 3.1417 divided by 2 added to 24". Either get a 41" belt or a 41.5" belt depending on what belt sizes are available, and how much adjustment you have.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
