looking to put hyd brakes on a 1931 chevy axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2012, 08:01 PM
all you need is 1955----1959 chevy truck brakes you need to use the inner& outer wheel bearings the hub,backing plate,and the drum 5 4/3 lug pattern 1/2 ton shoes and wheel cyclenders 3/4 ton has 6 lug will not work . you have to drill out your spindles to 1/2 for the bolts to work but the backing plate will goes on this is a neet trick i found out by accident {my brother had brakes from his 1959 chevy he was not using and i took a chance this is how i know it works. hope this helps chevy rodders p.s. wood sucks they should have built the chevys with a steel structure ha ha
The Following User Says Thank You to 31chevylq For This Useful Post:
35chevypu (09-30-2012)
S10 brakes on '58 Chevy truck strait axle? Captain America Suspension - Brakes - Steering 6 01-31-2012 04:27 AM
which spindle and rotor to use on 1931 graham axle so 5 lug GM wheel fits 1931 graham rod Suspension - Brakes - Steering 6 08-02-2010 04:25 PM
1931 chevy brakes john roose Suspension - Brakes - Steering 1 09-24-2008 01:55 PM
32 chevy front axle needs disc brakes karlslot Suspension - Brakes - Steering 4 04-28-2007 06:06 PM
1931 chevy gary felix Introduce Yourself 1 04-18-2006 12:37 PM
