Looking for Rearend info - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 03-13-2002, 09:22 AM
Rog_Van's Avatar
New Member
Post Looking for Rearend info
Has anyone had any experience with a Mopar 8-1/4 rearend? What kind of horsepower & torque can they handle? I can get one out of a 74 Dodge but I don't know anything about an 8-1/4.
Quick reply to this message
Old 03-13-2002, 11:16 AM
Phat's Avatar
Toy builder
Post
Not the best.It all depends on what your going to do with it. If you have to pay for it??or ?? Cause there is just no beating a 9 or 8 inch ford.They are cheap to fix,change ratio's and the market is geared toward them.If you get the rear for free and your putting it in a 300hp rod and you have to do nothing to it,hey why not use it. If you need to change bolt patterns and rebuild it and buy it.I say stick with whats cheap and known.There is a reason you see them in all cars and its not cause everbody reads the window stickers. What are you going to use it for???
Old 03-22-2002, 07:25 PM
Rog_Van's Avatar
New Member
Post
I'm thinking of putting one in a rod project of mine. I've got a 39 DeSoto with a 56 DeSoto 330cid hemi engine. With 600cfm 4bbl carb I should be around 350 hp & 425 ft/lbs torque. With a Dodge A-518 auto trans. Just something different to drive on the street.
Old 04-02-2002, 02:22 PM
F-1Rodder's Avatar
Post
If it is available and can be installed without a lot of headache, I would use it. It probably has the strength of a GM 8.2" which was stock behind a lot of Nova 4 speeds and some Camaros. Your weight is probably less. Now if you told me you were going to go to the track and enter the bracket eliminations, fit a set of slicks and use a trans break and high stall converter, I would recommend a big Ford or 8.875 GM. But it will live behind 350 hp on street rubber.
Old 06-17-2006, 12:42 PM
74 doger rearend ?
Where's granger Indiana at ? I got a 8 3/4 that would prolly fit if your doing a "C" body .
Old 06-17-2006, 01:24 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You have brought up a 4 year old post. I imagine the original question has been answered.
Please read dates on the archived posts.
thread is locked.
thx ,
Closed Thread
