Looking for a rebuild kit and instructions on a 62 Ford-a-matic C6 tranny. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2008, 01:38 PM
d&c repairs it all's Avatar
anybody out there ever rebuild a C6 tranny for a 62 Ford Fairlane? Know where to get the rebuild kit? And instructions?
thanks for any help or advice,
doug
Old 11-30-2008, 02:41 PM
Hey Doug
No problem, what all are you looking for and ATSG manual will get you through it I have built many of these Would be glad to help
Old 11-30-2008, 02:42 PM
I don't know much about transmissions but i did rebuild a ford AOD with the help of a video i got from a guy named ken he makes videos for a few different Ford transmissions and rear ends im not sure if i am aloud to put his wesite up without getting in trouble but i will try his website is www.badshoeproductions.com he is a real nice guy and has helped me out a bunch so i hope this helps.
Old 11-30-2008, 03:11 PM
Originally Posted by danthetransman
Hey Doug
Is this unit a cast iron or alum case??
Old 11-30-2008, 03:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
C-6 trans was not produced in 1962.
Has the trans in the 62 Ford car been changed? if not , it would be a cruise-o-matic trans.... probably a medium case cruise-O.
These trans had cast iron main case ,a removable bell housings usually aluminum material and an aluminum tail housing.
Old 11-30-2008, 04:20 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Crosley is correct (and I'm not surprised by that ) although it was likely marketed at the time as a "Ford-O-Matic"
Wikipedia has the evolutionary history of the Ford-O-Matic. Note that it "Ford-O-Matic" could have been a 2-speed for a while as well. Henry sure could be the "king of confusing terms", couldn't he?
Wikipedia actually has the complete list of all Ford Transmissions
The Crankshaft Coalition has some more information as well
Old 12-01-2008, 11:06 AM
back to you on the 62
Hey Doug
Have looked all over the place and can't find the rebuild kit for a 62 fairlane sports coupe, it was the Ford-o-matic tranny, 2 speed. What do you know about how to get parts? Thanks, doug
Old 12-01-2008, 11:17 AM
Thanks for the help, will check it out
Will check out the site, I think I've been on it before on a different auto project. thanks again. Doug
