Save your $$ and use the stock thickness & style Steels or thin Steels if your adding more Frictions. The Kolene's aren't as good as the advertising. The finish/coating doesn't last, flaking/peeling.
I tried them in a TH2004R Trans just to see how they'de do. As several told me not good. If you just want to try them you can get the Alto part #'s here>> http://www.altousa.com/pdf/catalogs/hiperfCatalog.pdf to see if your local Trans supply has them. Bulkpart changed there site name to match the Co. name = Makco, weird their Bulkpart site is still up, it does load much faster than the new one tho'. http://www.makcotransmissionparts.com/A727clutch.html |
I say, if you have the extra cash to lay out for Kolene Steels and either Alto Reds or Blue plate special clutches then go for it. I did a search on many sites about different clutches and steels before I rebuilt my TH350 last winter and pretty much everything I read said that they were a waist of money but since it was my money and my trans I tried it anyways and now I have a solid racing season of proof that they ARE worth every penny.
I have built many TH350s and of course I make all the mods that are necessary, as usual, but this time I used the Blue Plate special clutches and Kolene steels and with that being the ONLY change to my race car my 60' dropped from average 1.74 to 1.68 and my eight mile dropped from average 8.06 to the low 7.90s and of course my qtr mile times are about a tenth faster. My trans seems to only get better as it gets hotter also. I run two brackets and tend to have to hot lap my car so I can feel the difference. As far as the mods I do to my transmissions...just read Jakeshoes how to and that's pretty much what I do to all of my rebuilds. I should mention that if you are building a bracket car then that's the route I'd take but if it's only a street car then I personally would only use the standard Borg Warner clutches and that's only because of a $$$ standpoint because I have nothing negative to say about Kolene steels and Blue Plate special clutches. Hope this info was helpful to you. |
Thanks for the suggestions. I was looking for the best solid parts. Money wasn't really a factor as long as it was reasonable. I found transmissioncenter.net and they helped me out. I called them and they shipped out the kolene steels, red eagle clutch, and new gaskets for $135. I'm a happy camper.
Nice Charger,
Thats a descent price. A little cheaper here but, with S/H would be close. http://www.makcotransmissionparts.com/HP54005R-K.html |
| TCI "SIZZLER" Good tranny? Opinions welcome.. | sugar ray | Transmission - Rearend | 6 | 01-17-2009 12:37 AM |
| Dark brown tranny fluid | slyhog22056 | Transmission - Rearend | 6 | 10-12-2008 05:39 PM |
| 89 Astro van tranny problems, rebuild help questions | searay | Transmission - Rearend | 14 | 05-31-2008 04:26 PM |
| Tranny fluid heating up engine??? | black66 | Engine | 1 | 07-13-2003 09:18 PM |
| 70 roadrunner engine and tranny | Oddi | Engine | 1 | 11-23-2001 12:38 PM |
