Looking for the right tire size - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2005, 08:35 PM
Gametech's Avatar
New Member
I have a 1979 Chevy 1/2 ton, 2WD pickup. I'm wanting to run 15x10 wheels in the back, and 15x8 (or 8.5) in the front. The truck has not been lowered at all. If I run a 275/60/15 on the back, what would look the best on the front? Should I run a tire with the same outer diameter as the rear, or one that's smaller in diameter? I'm not really worried about giving the truck a noticeable rake... so maybe something in the same diameter? Let me know what you think. Thanks.
Old 01-30-2005, 08:49 PM
I suggest a smaller diameter on the front.......and possibly a little more narrow tire.
The smaller diameter is so that the tire cannot rub the fender.
And the narrower tire.....will be a LOT easier to drive........especially in the wet.
Old 01-31-2005, 10:02 AM
astroracer's Avatar
A 255/60 would look fine and give you a little "rubber rake".
Old 01-31-2005, 07:14 PM
Gametech's Avatar
New Member
So far, what I've found for the front is a 235/70/15, and then use an 8 inch wheel with it. Both it and the 275/60/15 have pretty much the same diameter. The truck seems to have a "slight" rake naturally, but not very much. Just enough to say it's not level...LOL. Not sure how the 235/70 will fit on an 8 inch wheel.
Old 02-01-2005, 11:54 AM
Max Keith's Avatar
what tire?
I would recommend running tires of nearly the same diameter on all 4 corners, even if they are different series tires, and a spare of that diameter. Driving a vehicle and having tire trouble when running two different diameter tires can be a pain, requiring either carrying 2 different spares or running a car with a lot of stagger from one side to the other, which can cause some handling problems when driving, particularly a strong tendency to pull to one side or the other.
Tire sizes of less than an 1 1/2 inch in circumference (approximately 1/2 inch in diameter), wont be much of a problem.
Old 02-01-2005, 06:55 PM
Gametech's Avatar
New Member
Thanks to all for the information, I think I have the right combination now for when I get everything changed over.
