Looking For Road Demon Owners
I just installed a Road Demon and tried some different jetting on it and am not really impressed with the throttle response or acceleration compared to the Edelbrock that I took off.
Anyone have the same carb that has a opinion one way or the other? I have the 625 on a Ford 390 used for towing. |
Read the instructions and watched the video more than once.
The idle is clean and off throttle is clean and precise, But just seems to lack the response and acceleration from a cruise to a power state. Tried several different jet sizes in the primary and secondary's and didn't notice any difference. Also tried PV change and Secondary spring. BTW: What did you end up doing to get it right on? Last edited by Tmod; 05-17-2004 at 12:56 PM. |
The use of a vacuum gauge was a huge benefit, played with the fuel pressure some until I found what it liked, Even fooled around with squiter nozzle sizes. My carb came with a 6.5 PV, after looking at the vacuum gauge and it coming in at around 15 - 16 inches, I went to a 9.5 PV and that helped a bit. One thing demons do like is a lot of spark timing advance.
I have my initial timing set at 16 degrees BTDC.
I used a vacuum gauge to set the idle mixture and that is ok, I have the screws turned out 3/4 from seated on both pri & sec. I also ended up with a 9.5 PV and a in gear idle vacuum of 16". |
