Looking for a rocker switch
Does anybody have a line on a good electrical supply store? I need a relatively small three position (on-off-on) self centering rocker switch suitable for use as a trim switch in a boat. None of the parts stores in town have one. I've found a few web sites so far but none that self center or they are not small enough.
hi there.. just joined this site... and saw this question...
here is a small switch that should work for you... http://www.allelectronics.com/make-a...-HANDLE/1.html i would probably encase it in silicone sealer after attaching the wires to it.. and use a gm weather pack connector... and make a few spares to change it out in a few minutes if need be... you might want to open a an extra to see how the toggle is sealed... water gets into everything... waynep |
Thanks Vince, that's a great catalog. I found the exact switch I need. It's a momentary on-off-momentary on rocker.
This little guy right here |
the switch just activates the pump solonoid so it does not need to be any kind of heavy duty, that switch looks perfect.. I bet that if you took your throttle lever apart to pull the factory switch out, that 1 would slip right in. is your trim system not working or are you doing custom controls?
I know what the switch is for. The shift lever is apart and the switch is not working properly.
Just purchased one today at Ace Hardware!!! $6 and some change
| fitting switch nuts and knobs to short shaft | TheCiscoKid | Electrical | 4 | 03-28-2008 03:58 PM |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| lock-up converter disable | 54p.u. | Transmission - Rearend | 5 | 12-14-2006 02:19 PM |
| Starter switch stock to modified wiring question. | Kallie49 | Electrical | 5 | 06-23-2006 06:01 PM |
| older headlight switch smoking! | bigfred1958 | Electrical | 9 | 02-15-2004 08:31 PM |
