looking for simple aftermarket smog systems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2007, 11:35 PM
does anyone out there know of any simple to install easy emissions control systems? . hopefully aftermarket and cheap. spacificaly i am talking about small block chevy 350 motors, Both carb and fuel injected. I am moving to the beautiful sunny smogged state of cali. Apperantly they are not as enthusiastic about my gas guzzling rubber burning toys as I am but I dont want to sell them. I built them myself. Any thaughts Welcome...
Old 12-29-2007, 01:43 AM
powerrodsmike's Avatar
Wiki Edits: 161
What year is your car(s)?
If you want to bring a car newer than a 1975 model into Ca it needs to have the smog equipment that was originally installed on the car from the factory, if you put a newer motor in the car, it probably needs to have all the stuff for that year motor, unless it's appearance doesn't give away the fact that it is newer...(don't count on the referree being dumb, either)
If the car is older than 1975, it is probably exempt.
As far as I know, there is no such thing as an aftermarket emission control system. I do know that there are companies that make a killing on selling used smog parts for guys who ditched theirs. I paid 175.00 for a used egr valve for my motorhome one time that I couldn't find anywhere else.
It's illegal to keep them registered out of state, for the purpose of skating around smog laws.
Later, mikey
BE different....ACT normal.
California Smog Law Smoked Rubber Off-Topic 18 08-08-2011 08:25 AM
smog pump code again! scholman Electrical 4 02-11-2006 07:00 PM
smog, smog, smog....CA smog , failed. jakeslim Engine 12 08-20-2005 11:59 AM
CA and EPA Smog Regs bluesman123 Engine 5 05-11-2004 09:51 PM
smog pump gone 68_6cyl_camaro Engine 2 04-27-2003 12:37 AM
