Looking for some rear end! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2002, 07:56 AM
Maverick's Avatar
Post Looking for some rear end!
Hey guys! Iam in search for a rear end for my '49 Chevy Truck. Going use some sort of a GM probably out of a Nova or something. Whats involved in Re-building one? What do I need to look for when Iam looking? Thanks for 'da in put! :p
Old 08-29-2002, 09:48 AM
SAE Member; ASE Master Cert
Post
My recommendation is to go with an early 12-bolt as they are fairly easy to work on and get parts for, and are pretty strong. When looking, make sure that everything turns smooth and easy. Do this by turning the pinion by hand. Take off the inspection cover and check for rust and broken gear teeth. Good luck.
Old 08-29-2002, 11:02 AM
Maverick's Avatar
Post
We have a "U Pull it" bone yard here. And I quess the EPA makes them drain all the fluids from the cars. So on all the rear ends the pan is off of them. Guess it would be a good idea to stay away from those? HUH? I just like the place cause they have all the cars parked in order to MFG and up off the ground and lined up like a parking lot.
